[gdal-dev] error adding ecw on Ubuntu 10.4 (lucid)
Marius Jigmond mariusjigmond at hotmail.com
Sun Feb 6 16:27:11 EST 2011
If that doesn't work, going back to what Even said earlier:
1. create a gdal_plugins.conf file in /etc/ld.so.conf.d/ with one
line: /usr/lib/gdal17plugins
2. sudo ldconfig
-marius
On Sun, 2011-02-06 at 19:08 +0100, Even Rouault wrote:
> Le dimanche 06 février 2011 19:00:03, Matt Wilkie a écrit :
> > > Check that the gdal_ECW.so (or whatever is name is) is installed in the
> > > GDAL plugin directory and then do a ldd on this .so to see if the ECW
> > > SDK .so are reachable. You might need to adjust the /etc/ld.so.conf or
> > > LD_LIBRARY_PATH to add them.
> > Is this searchable: ?
> Looks ok.
> Perhaps try setting the environment variable GDAL_DRIVER_PATH to
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
