[gdal-dev] MSSQL2008 Driver and OGR/Python
geographika
geographika at gmail.com
Mon Feb 7 10:35:04 EST 2011
Thanks Tamas for the quick reply.
I've been trying a few more combinations, and I now have it working.
In the geometry_columns table the first record works - when I duplicate
the schema name in the the f_table_schema and f_table_name fields. The
second does not.
In fact I can put any entry in the f_table_schema field - it appears to
be ignored.
[f_table_catalog], [f_table_schema] ,[f_table_name],
[f_geometry_column],[coord_dimension],[srid],[geometry_type]
DbName any value can be put here
schemaname.mytable GEOMFIELD 2 32768 MULTIPOLYGON
DbName schemaname mytable GEOMFIELD 2 32768 MULTIPOLYGON
The following now works (with the first record - not the second):
conn_string = "MSSQL:server=W08-SQL08;database=DbName;Integrated
Security=true;"
ds = ogr.Open(conn_string)
lyr = ds.GetLayerByName('schemaname.mytable') #schema name always has to
be passed here
If this is not the intended behaviour I can create a ticket, otherwise
thanks for your time (and drivers!).
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On 07/02/2011 13:26, Tamas Szekeres wrote:
> 2011/2/7 geographika <geographika at gmail.com
> <mailto:geographika at gmail.com>>
> Hi,
> When working with the SQL Server 2008 OGR driver I presume it is
> necessary to create the following metadata tables?
> geometry_columns
> spatial_ref_sys
> There appears to be no way to do this automatically in Python, but
> if I import a single dataset into the database it is created
> automatically. I can then use:
> conn_string = "MSSQL:server=W08-SQL08;database=dbname;Integrated
> Security=true;"
> lyr = ds.GetLayerByName('testdata')
> Hi Seth,
> Those metadata tables are required since MSSQL2008 doesn't have a
> builtin way to store all of these information. When importing the
> first table it should indeed be created from scratch. With regards to
> spatial_ref_sys it could also be populated by using the corresponding
> postgis script.
> It would be nice to be able to connect to a layer without having
> to register it with the geometry_columns table using a connection
> string such as:
> Security=true;tables=myschema.testdata(GEOMFIELD)"
> As this is not currently possible I manually added a record to
> geometry_columns for an existing spatial table in my database.
> This is in a separate schema so I used the following SQL:
> INSERT INTO [geometry_columns] ([f_table_catalog],
> [f_geometry_column],[coord_dimension],[srid],[geometry_type])
> VALUES ('DbName', '*myschema*', 'testdata', 'GEOMFIELD', 2, 32768,
> 'MULTIPOLYGON')
> However using SQL Profiler when trying to connect to the layer it
> always tries to find this layer in *dbo*.
> exec DbName..sp_columns N'testdata',N'*dbo*',N'DbName',NULL
> As it does not exist in dbo the connection never succeeds, and I
> cannot connect to any of the layers in the database.
> I can add this to trac if it is an issue - I just want to first
> make sure I've not made any obvious errors.
> Specifying the schema in geometry_columns should be working and
> myschema.mytable(GEOMFIELD) should also be a working option. So please
> file a ticket with this issue if you encounter problems here.
> Best regards,
> Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110207/bdb4c1ec/attachment.html
