[gdal-dev] [python-ogr] GetNumPoints from geometry
Ari Jolma
ari.jolma at gmail.com
Wed Feb 9 09:44:47 EST 2011
On 02/09/2011 04:19 PM, Frank Broniewski wrote:
> Hi,
> just a quick question: isn't GetNumPoints implemented on a geometry in
> ogr python?
There are OGR_G_GetPointCount in ogr_api.h and GetPointCount method in
the Geometry class in Swig bindings.
Hm. It seems that NumPoints is the name of the method in the OGC simple
features standard (it is defined for LineStrings).
Ari
> Neither GetNumPoints() nor getNumPoints() (small g) work.
> The passed in geometry is a geometry object from a
> geometry = feature.GetGeometryRef()
> call and the geometry is of type 'LINESTRING' taken from
> geometry.GetGeometryName() ...
> code:
> def line_nodes(geometry):
> nodes = list()
> for point_index in xrange(geometry.GetNumPoints()):
> ogr_point = ogr.OGRPoint()
> point = geometry.GetPoint(point_index, ogr_point)
> dimenion = point.GetCoordinateDimension()
> if dimension == 3:
> list.append(point_index, point.GetX(), point.GetY(),
> point.GetZ())
> else:
> list.append(point_index, point.GetX(), point.GetY())
> return nodes
> raises an AttributeError
> for point_index in xrange(geometry.getNumPoints()):
> File "C:\Python26\lib\site-packages\osgeo\ogr.py", line 2672, in
> <lambda>
> __getattr__ = lambda self, name: _swig_getattr(self, Geometry, name)
> File "C:\Python26\lib\site-packages\osgeo\ogr.py", line 34, in
> _swig_getattr
> raise AttributeError,name
> AttributeError: GetNumPoints
> Many thanks
> Frank
