[gdal-dev] [python-ogr] Transform datasource problems
Frank Broniewski
brfr at metrico.lu
Thu Feb 10 03:09:45 EST 2011
Even,
thank you for your verbose and helpful answer!
Am 09.02.2011 20:24, schrieb Even Rouault:
> Several points :
> 1) The implementation of Layer.GetFeature() is only efficient for just a few
> drivers (shapefile). Other drivers will need to sequentially read from the first
> feature ... So use GetNextFeature()
Are these informations somewhere documented? I had a look at the docs
here [1],[2], but didn't find anything related. What about iterating
over layers in a datasource, or fields in a feature? Are there similar
concerns?
> 2) The real bug is that you don't rewrite the feature to its layer. So you
> need to add a target_layer.SetFeature(target_feature)
Ah, Ok, so the link/object relation between the layer and the feature is
lost, once the feature is fetched? Since most things are done by
reference in Python, this was not obvious to me. Thanks for pointing
this out!
> 3) But what you are doing is really what ogr2ogr.py does, although your
> approach will be less efficient as you first copy the layer and then rewrite each
> of its feature.
Yes, I know. And I had a deep look at the ogr2ogr.py script before
writing to the list, but frankly this is too much for me. It looks more
like a c/c++ script than anything else to me - no functions, no classes,
nothing from the python zen ... I really got lost in the middle of the
script :-) but that's just a cause of my insufficient programming skills.
> For best performance, you should rather :
> a) create a target layer from scratch
> b) copy the feature definition from the source layer to the target layer
> c) iterate over the source features, for each source feature, create a target
> feature (Feature.SetFrom(other_feature)). reproject the geometry, assign it to
> the target feature, and Layer.CreateFeature(target_feature)
> Basically a stripped version of ogr2ogr.py
I will make a new version and post it here on the list, so everyone can
have a look and maybe learn something from it
Frank
[1] http://www.gdal.org/ogr/ogr_formats.html
[2] http://www.gdal.org/ogr/classOGRLayer.html
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
