[gdal-dev] ERROR 1: Too many points (440 out of 441) failed to
transform, unable to compute output bounds.
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 10 16:50:19 EST 2011
On 11-02-10 01:43 PM, Hailey Eckstrand wrote:
> But the stays the same:
> ERROR 1: Too many points (440 out of 441) failed to transform,
Hailey,
I tried with your file and with debugging on and saw the following message:
WARP: Recompute out extent with CHECK_WITH_INVERT_PROJ=TRUE
I read through the code in gdalwarp.cpp and it seems this is something
added, perhaps by Even, to check that the output area selected is appropriate
and can be effectively reprojected. I tested a few points between the somerc
projection and WGS84 with the PROJ.4 "cs2cs" command and found there was often
poor fidelity - likely indicating that points were being transformed that
are far outside the well defined area for the projection.
I did successfully run your gdalwarp command by adding:
--config CHECK_WITH_INVERT_PROJ FALSE
on the commandline, but I'm not convinced that the results are actually
very accurate or meaningful. I'd suggest you reconsider whether you really
want to try and warp nearly the whole world to a swiss oblique mercator
projection.
Possibly Even could consider improving the error reporting in this case
if the issue is really that the transformation is not round tripping well.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
