[gdal-dev] MSVC warnings changes
Frank Warmerdam
warmerdam at pobox.com
Fri Feb 11 17:23:51 EST 2011
Folks,
I have spent several hours today cleaning up warnings when building with
Microsoft Visual C++.
The first step was to move warning suppression out of gdal/port/cpl_port.h
and instead passing warning suppression via the compiler commandline line.
This is accomplished by setting of the WARNFLAGS macro in nmake.opt with
a warning level (/W4 now) and a set of specific warnings to be disabled
(using /wd4127, etc). Moving the disabling out of cpl_port.h is important
because it means GDAL policy of disabling some warnings will not impact
applications including gdal.h.
The warning I have disabled are things I feel are reasonable practice and
not worth seeing as warnings. Mostly this is the same as the warnings
disabled in cpl_port.h, but I have add a few including warnings related
to signed/unsigned comparison mismatches. These drive me nuts and have not
(for me) yet lead to identifying a real error.
I have also introduced the SOFTWARNFLAGS macro. This disables a bunch more
warnings, and is used in some of the submakefiles building code from external
sources that we can't practically alter. This includes stuff like zlib,
and libjpeg.
I have made a variety substantial pass over the GDAL source tree building
with MS Visual Studio 2008 Express Edition and trying to adjust the code to
clean away warnings and in a few cases adding extra local warning disablers
either in makefiles or using the pragma in the code. These changes can
mostly be seen in these commits:
http://trac.osgeo.org/gdal/changeset/21684
http://trac.osgeo.org/gdal/changeset/21680
The main warnings I'm still aware of are related to the MITAB and AVCE00
libraries. These changes need to be upstreamed and were sufficiently involved
that I put them off. Beyond that I was able to get a pretty much warning
free build on /W4.
Going forward I am hoping we can balance appropriate choice of warnings
to suppress globally and adjustments to the code to keep our windows
build warning-clean. Hopefully this will help us be more vigilant in
addressing new warnings that do pop up.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
