[gdal-dev] generate vrt from grass data
Even Rouault
even.rouault at mines-paris.org
Sun Feb 13 13:40:20 EST 2011
Le dimanche 13 février 2011 05:57:24, Massimo Di Stefano a écrit :
> Hi All
> i'm using python-gdal to generate vrt file, it works fine but for some data
> like :
> (from the spearfish dataset) the raster file :
> spearfish60/PERMANENT/cellhd/tractids
> gdalinfo give me :
> http://www.geofemengineering.it/data/vrtlog.txt
> tring to generate a vrt freeze my shell and i have to force quit it.
> i tested it on osx 10.6.6 (gdal.framework, grass6.5.svn)
> and on linux debian sid (gdal svn , grass65 svn)
> i got the same results ( ctrl+D ctrl+C doesn't work, force quit the shell)
Should be fixed by http://trac.osgeo.org/gdal/ticket/3961
The huge color table revealed quadratic performance in the XML serialization.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
