[gdal-dev] Re: GetProjectionRef() difference 1.8 vs 1.7.2
Livneh Yehiyam yehil at rafael.co.il
Tue Feb 15 00:17:41 EST 2011
From my experience, setting the georeference but leaving the transform blank will cause applications like GlobalMapper to fail reading the file (I noticed that with jp2k but I suppose it will happen with NITF as well).
Sent from my mobile
Yehiyam
Subject: [gdal-dev] Re: GetProjectionRef() difference 1.8 vs 1.7.2
Date: 15 פברואר 2011 03:29
> You can still force compute an approximate
> geotransform by calling GDALGCPsToGeoTransform( nGCPCount, psGCPs,
> adfGeoTransform, TRUE ). And the projection can indeed be fetched by
> GDALGetGCPProjection() when GCPs are returned instead of a geotransform.
These NITFs contain RPCs, so I mostly am unconcerned with the geotransform,
exact or approximated. However, proper interpretation of the RPCs requires
knowledge of the projection reference. In these cases, it seems somewhat
circuitous to look for a projection reference among the GCPs. If
GDALGCPsToGeoTransform() fails to return a geotransform, would there be any
reason not to set the projection reference to the GCP projection (but to
still have GetGeoTransform() return CE_Failure)? Is the dataset projection
reference ever set to something different than the GCP Projection?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GetProjectionRef-difference-1-8-vs-1-7-2-tp6024512p6025941.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
a
This message (including any attachments) issued by RAFAEL- ADVANCED DEFENSE SYSTEMS LTD.
(hereinafter "RAFAEL") contains confidential information intended for a specific individual and purpose, may
constitute information that is privileged or confidential or otherwise protected from disclosure. If you are not
the intended recipient, you should contact us immediately and thereafter delete this message from your
system. You are hereby notified that any disclosure, copying, dissemination, distribution or forwarding of this
message, or the taking of any action based on it, is strictly prohibited. If you have received this e-mail in error,
please notify us immediately by e-mail mailto:lawraf at rafael.co.il and completely delete or destroy any and all
electronic or other copies of the original message and any attachments thereof.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110215/0b9b928c/attachment-0001.html
