[gdal-dev] lat lon matrix tables to geotif
Nikolaos Hatzopoulos
nhatzop at gmail.com
Wed Feb 16 01:48:24 EST 2011
So you are talking for something like this:
Example VRT file for data (just to show the geolocation metadata reference):
<VRTDataset rasterXSize="2048" rasterYSize="964">
<Metadata domain="GEOLOCATION">
<MDI key="X_DATASET">data.lon.vrt</MDI>
<MDI key="X_BAND">1</MDI>
<MDI key="Y_DATASET">data.lat.vrt</MDI>
<MDI key="Y_BAND">1</MDI>
<MDI key="PIXEL_OFFSET">0</MDI>
<MDI key="LINE_OFFSET">0</MDI>
<MDI key="PIXEL_STEP">1</MDI>
<MDI key="LINE_STEP">1</MDI>
</Metadata>
<SRS> stuff goes here</SRS>
<VRTRasterBand dataType="UInt16" band="1" subClass="VRTRawRasterBand">
<ImageOffset>1500</ImageOffset>
<PixelOffset>10</PixelOffset>
<LineOffset>22180</LineOffset>
<ByteOrder>LSB</ByteOrder>
</VRTRasterBand>
</VRTDataset>
On Tue, Feb 15, 2011 at 10:34 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> On 11-02-15 01:20 PM, Nikolaos Hatzopoulos wrote:
>> So we have three tables:
>> one matrix for latitude values
>> one matrix for longitude values
>> one matrix for our data values
>> all the matrix have the same dimensions
>> how we can convert these three tables to geotif using gdal??
> Mikos,
> This is a georeferencing method I refer to as "geolocation grids". It is
> not a supported organization in GeoTIFF so there is no way to produce
> a GeoTIFF with the above data where the meaning of the latitude and
> longitude
> values will be well understood.
> If you want to use the resulting geotiffs in non-GDAL applications I
> think you are best just turning each matrix into a separate TIFF file
> with appropriate file names to suggest the meaning to and end user.
> Another option is to just rectify the image data into a normal north
> up rectified grid and write that to GeoTIFF. Such an output would be
> easily exploited in any GeoTIFF reading application.
> It also is possible to use metadata to associate the latitude and longitude
> as geolocation grids within a GeoTIFF file in a way that some GDAL
> applications (like gdalwarp) could take advtange of. This requires setting
> up very specific metadata items to relate the data. The metadata required
> (for geotiff or other formats) is listed in RFC 4:
> http://trac.osgeo.org/gdal/wiki/rfc4_geolocate
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110215/6b0b3212/attachment-0001.html
