[gdal-dev] Gdal2tiles in Gdal18 and creating KMZ files
brian rush at winkey.org
Wed Feb 16 17:35:14 EST 2011
Roland
the problem is in /12/1211/2558.kml line 26
<href>2558.png</href>
this should be a relative path from the root of the zipfile not from
2558.kml
Brian
On Wed, 2011-02-16 at 15:14 -0500, Roland Duhaime wrote:
> I am following the instructions for creating one KMZ file that are
> posted here:
> http://trac.osgeo.org/gdal/wiki/UserDocs/Gdal2Tiles
> I am using gdal2tiles under the "gdal" package 1.8.  I have having
> success creating superoverlays and the related folder structure.  I am
> able to read the created doc.kml in Google Earth.  However, when I
> attempt to zip up the folder structure using 7zip and rename the file
> to test.kmz, the file doesn't read properly in Google Earth (GE).  GE
> zooms into the correct location but all I see is a red "x".
> Compressing the superoverlay structure seems to break the link between
> the doc.kml file and the png files.  As an example, I have created a
> tiny (21 KB)  example and placed it here:
> http://www.edc.uri.edu/Personal/roland/test.kmz
> I am curious if someone had some insight.
> All the Best,
> Roland
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
