[gdal-dev] Segmentation fault using gdal_translate in 1.8.0
Derrick.Wong at csiro.au
Thu Feb 17 23:27:21 EST 2011
Skipped content of type multipart/alternative-------------- next part --------------
Driver: netCDF/Network Common Data Format
Files: ga_fixed2_1e75_911d_7726.nc
Size is 179, 180
Coordinate System is `'
Origin = (147.124923499972280,-39.969630500001372)
Pixel Size = (0.008332999999993,-0.008333000000000)
Metadata:
NC_GLOBAL#cdm_data_type=Grid
NC_GLOBAL#Conventions=CF-1.0, COARDS, Unidata Dataset Discovery v1.0
NC_GLOBAL#Easternmost_Easting=148.612
NC_GLOBAL#geospatial_lat_max=-39.9738
NC_GLOBAL#geospatial_lat_min=-41.4654
NC_GLOBAL#geospatial_lon_max=148.612
NC_GLOBAL#geospatial_lon_min=147.129
NC_GLOBAL#history=2011-02-01 http://apacsrv6/thredds/dodsC/ga/onshore_only_Bouguer_geodetic_fixed2
.nc
2011-02-01 http://apacsrv6.arrc.csiro.au/erddap/griddap/ga_fixed2.nc?onshore_only_Bouguer_geodetic[(
-41.46540400000144):(-39.973797000001376)][(147.12908999997228):(148.61236399997108)]&.draw=surface&
.vars=longitude|latitude|onshore_only_Bouguer_geodetic&.colorBar=|||||&.land=under
NC_GLOBAL#infoUrl=http://apacsrv6/thredds/dodsC/ga/onshore_only_Bouguer_geodetic_fixed2.nc.html
NC_GLOBAL#institution=APACSRV6
NC_GLOBAL#license=The data may be used and redistributed for free but is not intended
for legal use, since it may contain inaccuracies. Neither the data
Contributor, ERD, NOAA, nor the United States Government, nor any
of their employees or contractors, makes any warranty, express or
implied, including warranties of merchantability and fitness for a
particular purpose, or assumes any legal liability for the accuracy,
completeness, or usefulness, of this information.
NC_GLOBAL#Metadata_Conventions=CF-1.0, COARDS, Unidata Dataset Discovery v1.0
NC_GLOBAL#Northernmost_Northing=-39.9738
NC_GLOBAL#Source_Software=ESRI ArcGIS
NC_GLOBAL#sourceUrl=http://apacsrv6/thredds/dodsC/ga/onshore_only_Bouguer_geodetic_fixed2.nc
NC_GLOBAL#Southernmost_Northing=-41.4654
NC_GLOBAL#standard_name_vocabulary=CF-12
NC_GLOBAL#summary=APACSRV6 data from http://apacsrv6/thredds/dodsC/ga/onshore_only_Bouguer_geodeti
c_fixed2.nc.das .
NC_GLOBAL#title=Ga onshore only Bouguer geodetic fixed2
NC_GLOBAL#Westernmost_Easting=147.129
onshore_only_Bouguer_geodetic#coordinates=lon lat
onshore_only_Bouguer_geodetic#esri_pe_string=GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID
[\"WGS_1984\",6378137.0,298.257223563]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433
onshore_only_Bouguer_geodetic#ioos_category=Unknown
onshore_only_Bouguer_geodetic#long_name=onshore_only_Bouguer_geodetic
onshore_only_Bouguer_geodetic#missing_value=0.000000e+000
onshore_only_Bouguer_geodetic#units=Degree
latitude#_CoordinateAxisType=Lat
latitude#actual_range=-41.4654, -39.9738
latitude#axis=Y
latitude#ioos_category=Location
latitude#long_name=Latitude
latitude#standard_name=latitude
latitude#units=degrees_north
longitude#_CoordinateAxisType=Lon
longitude#actual_range=147.129, 148.612
longitude#axis=X
longitude#ioos_category=Location
longitude#long_name=Longitude
longitude#standard_name=longitude
longitude#units=degrees_east
Corner Coordinates:
Upper Left ( 147.1249235, -39.9696305)
Lower Left ( 147.1249235, -41.4695705)
Upper Right ( 148.6165305, -39.9696305)
Lower Right ( 148.6165305, -41.4695705)
Center ( 147.8707270, -40.7196005)
Band 1 Block=179x1 Type=Float32, ColorInterp=Undefined
NoData Value=0
Metadata:
NETCDF_VARNAME=onshore_only_Bouguer_geodetic
