[gdal-dev] Re: GCP list projection
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Feb 18 05:51:27 EST 2011
Vadim,
(0,1,0,0,0,1) is the default transform and will be returned even in case of
an error.
On Fri, Feb 18, 2011 at 2:09 PM, Vadim Shlyakhov <vadp.devl at gmail.com>wrote:
> Frank Warmerdam <warmerdam <at> pobox.com> writes:
> > In theory it could make sense to have a dataset with a dataset level SRS
> > and geotransform, and also GCPs with a different SRS. In some cases the
> GCPs
> > are in a particular SRS (say lat/long) just because it is a convenient
> > coordinate system to collect the GCPs, not because it is representative
> of
> > the geometry of the image.
> Thanks Frank, That was actually my understanding. BSB and Ozi have their
> GCPs in
> long/lat, so I thought that a feature for such a case.
> So, if you have GCP SRS, you don't need SRS set at the dataset level, do
> you?
> BTW I've noticed if a dataset doesn't have a geotransform, then
> ds.GetGeoTransform() returns (0.0, 1.0, 0.0, 0.0, 0.0, 1.0). Is that a
> feature
> or a bug?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110218/df8e675e/attachment.html
