[gdal-dev] open shapefile from server
Even Rouault
even.rouault at mines-paris.org
Fri Feb 18 14:51:53 EST 2011
Le vendredi 18 février 2011 15:53:45, Mateusz Loskot a écrit :
> On 18/02/11 14:25, Chaitanya kumar CH wrote:
> > Rashad,
> > Read the documentation on VSIInstallCurlFileHandler() in the cpl_vsi.h
> > file documentation.
> > http://www.gdal.org/cpl__vsi_8h.html
> Nice features indeedb, but it does not guarantee "without
> downloading the whole file", does it? It depends on what part of
> file is being read, doesn't it?
With GDAL 1.8.0, you can try :
poDS = OGRSFDriverRegistrar::Open("
/vsicurl/http://mywebsite.com/shapefiles/myshape.shp", FALSE );
Yes /vsicurl is no magic. If there's a VSIFReadL() call that reads the whole
file in a single gulp, then the whole file would be downloaded of course, but
most GDAL/OGR drivers try to only read the minimum necessary at open time. In
the case of the shapefile driver, it will read essentially only the header of
the .shp, .shx and .dbf files
Extra bonus: you can combine /vsizip with /vsicurl. For example, try :
ogrinfo -ro -so -al --debug on
/vsizip/vsicurl/http://www.aprsworld.net/gisdata/world/world.zip
Expected result :
VSICURL: GetFileSize(http://www.aprsworld.net/gisdata/world/world.zip)=3436277
response_code=200
VSICURL: Downloading 3424256-3440639
(http://www.aprsworld.net/gisdata/world/world.zip)...
VSICURL: Downloading 3407872-3424255
VSICURL: Downloading 3391488-3407871
VSICURL: Downloading 3375104-3391487
VSICURL: Downloading 3358720-3375103
VSICURL: Downloading 0-16383
VSICURL: Downloading 16384-81919
OGR:
OGROpen(/vsizip/vsicurl/http://www.aprsworld.net/gisdata/world/world.zip/0x1f35830)
succeeded as ESRI Shapefile.
INFO: Open of
`/vsizip/vsicurl/http://www.aprsworld.net/gisdata/world/world.zip'
using driver `ESRI Shapefile' successful.
OGR: GetLayerCount() = 1
Layer name: world
Geometry: Polygon
Feature Count: 244
Extent: (-180.000000, -89.900000) - (180.000000, 83.674733)
Layer SRS WKT:
(unknown)
CAPITAL: String (64.0)
APPROX: Real (15.0)
AREA: Real (20.15)
SOURCETHM: String (16.0)
> Best regards,
