[gdal-dev] Mosaicking Orthos
Marius Jigmond
mariusjigmond at hotmail.com
Sun Feb 20 14:16:36 EST 2011
Hi Zoltan,
Are you sure that the white you see is a pure 255/255/255? Albeit, the
nearblack with its near default of 15 would have likely taken care of
that.
If you load two othophotos in QGIS and specify the transparent pixels,
does the collar between the orthophotos disappear?
Regarding the warnings see:
http://www.mail-archive.com/gdal-dev@lists.osgeo.org/msg06960.html
-marius
