[gdal-dev] Re: [mapserver-users] OGR VRT ODBC connection problem
Peter J Halls
P.Halls at york.ac.uk
Mon Feb 21 03:14:58 EST 2011
Brent,
firstly, whilst SQLPLUS is a useful tool to ensure the Oracle environment is
correctly configured, it does not test ODBC - nor does the very much nicer, Java
based, SQL Developer, which is also not restricted to use with Oracle.
Secondly, how many tables are there in your Oracle tablespace? I currently
have around 70 or 80 and OGR takes forever to start. OGR reads the schema for
every table in the tablespace, trying to identify the spatial tables and
pre-load the key data in readiness. If you have a lot of tables, the
initialisation step may certainly seem to hang.
Thirdly, enabling debug in GDAL will enable you to track a lot of what is
going on and should enable you to quickly determine what is causing the hang -
although fixing it may take rather more effort, of course.
Lastly, I built GDAL against the Oracle Call Interface (OCI) libraries, not
ODBC: this connects to Oracle in a similar manner to that used by the Oracle
products and I find it to be fast and efficient.
Best wishes,
Peter
pcreso at pcreso.com wrote:
> Thanks Stephen,
> I should have included this in my first msg, apologies, but thanks for the reply.
> I'm running GDAL v1.6.1, from
> ogrinfo --version
> GDAL 1.6.1, released 2009/05/11
> And, running isql (from unixodbc) also works.
> isql --help
> unixODBC 2.2.12
> isql -v metp niwatest niwatest
> libnuma: Warning: /sys not mounted or no numa system. Assuming one node: No such file or directory
> | Connected! |
> | sql-statement |
> | help [tablename] |
> | quit |
> SQL> select count(*) from land_station;
> | COUNT(*) |
> | 8338 |
> So isql succeeds, and is definately using ODBC.
> ogrinfo just hangs. Both have the /sys warning msg, which I am ignoring.
> I'm still lost with respect to this....
> Thanks,
> Brent
> --- On Mon, 2/21/11, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> Subject: Re: [mapserver-users] OGR VRT ODBC connection problem
> To: pcreso at pcreso.com
> Cc: mapserver-users at lists.osgeo.org, gdal-dev at lists.osgeo.org
> Date: Monday, February 21, 2011, 2:12 PM
> Hi Brent,
> I'm certainly not an expert on this, but I think the issue might be that
> sqlplus does not use an ODBC connection it uses some proprietary Oracle
> socket protocol to connect.
> Do you have ODBC services setup, configured and running on the Linux
> host? How have you verified this?
> If not then this is likely the issue. Sorry I don't use ODBC, so I can't
> help much more then this.
> -Steve W
> On 2/20/2011 7:12 PM, pcreso at pcreso.com wrote:
>> Hi,
>> Apologies for the cross posting, but I figure there are experts on both
>> lists.
>> I'm trying to get a ogr virtual connection working from a Linux host to
>> a remote Oracle DB to use mapserver for a WFS service providing the
>> required data..
>> ODBC is working, eg:
>> sqlplus user/user at metp <mailto:niwatest/niwatest at metp>
>> 8338
>> etc...
>> However, when testing with ogr2ogr, I get:
>> ogrinfo ODBC:user/user at metp land_station
>> and the terminal window hangs, I'm unable to get any response, & have to
>> kill the connection to continue.
>> Any suggestions?
>> Thanks,
>> Brent Wood
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> gdal-dev mailing list
Peter J Halls, GIS Advisor & Acting Team Leader Applications Support Group,
Information Directorate, University of York
Telephone: 01904 323806 Fax: 01904 323740
Snail mail: C/O IT Services, University of York, Heslington, York YO10 5DD
This message has the status of a private and personal communication
