[gdal-dev] Re: [Qgis-developer] Issue saving shapefiles with REAL15
values
Anita Graser
anitagraser at gmx.at
Tue Feb 22 07:37:26 EST 2011
Am 22.02.2011, 13:19 Uhr, schrieb Paolo Cavallini <cavallini at faunalia.it>:
> Il giorno mar, 22/02/2011 alle 13.16 +0100, Anita Graser ha scritto:
>> I have a shapefile containing fields of type REAL15. I'd like to cut an
>> area of interest out of this shapefile using QGIS "Save as ..."
>> function.
>> The resulting shapefile still has fields of type REAL15 but the
>> contained
>> values are botched, e.g. 10400000603695 becomes -2147483648.
>> I'm uncertain whether the problem lies with GDAL or QGIS' use of GDAL.
> Which versions?
OSGeo4W r15203 with GDAL 1.8.0
>> It would be great if this problem could be resolved. Unfortunately, I
>> can't share the original (commercial) dataset.
> You can extract just one record, and share that one.
How? If I use QGIS, the values will be broken.
Best wishes,
Anita
