[gdal-dev] How to use GDAL C++ dynamically?
Mikhail Tchernychev
misha at mail.geometrics.com
Tue Feb 22 17:14:50 EST 2011
Hello List,
I wonder if someone could point me into the right direction. I would
like to use
GDAL as loaded DLL at run time, with LoadLibray() call under windows
and corresponding
calls under Linux. I see that most of the functions are virtual, so it
seems it is made
with this in mind. I am trying to compile simple program:
#include "stdafx.h"
#include <windows.h>
#define CPL_DLL
#include "ogrsf_frmts.h"
typedef void (* pOGRRegisterAll)();
typedef OGRSFDriverRegistrar * (*pGetRegistar)();
int _tmain(int argc, _TCHAR* argv[])
const char *pszDriverName = "ESRI Shapefile";
HMODULE hDll = LoadLibrary("gdal18.dll");
if(!hDll) {
fprintf(stderr,"Cannot load library\n");
exit(0);
pOGRRegisterAll pRegFunc =
(pOGRRegisterAll)GetProcAddress(hDll,"OGRRegisterAll");
(*pRegFunc)();
OGRSFDriver *poDriver;
OGRSFDriverRegistrar * poRegistrar;
pGetRegistar pRegistrarFunc =
(pGetRegistar)GetProcAddress(hDll,"?GetRegistrar at OGRSFDriverRegistrar@@SAPAV1 at XZ");
if(pRegistrarFunc == NULL )
printf( "Cannot get registrar\n");
exit( 1 );
poRegistrar = (*pRegistrarFunc)();
if( poRegistrar == NULL )
printf( "Cannot get poRegistrar\n");
exit( 1 );
// link error here:
poDriver = poRegistrar->GetDriverByName(pszDriverName);
if( poDriver == NULL )
printf( "%s driver not available.\n", pszDriverName );
exit( 1 );
return 0;
This is just part of the GDAL API tutorial.
I see two problems here:
1. I have to use C++ mangled names, which is not very nice. Is there
.DEF file for GDAL
with meaningful names?
2. I got a link error, which apparently clear why, because
GetDriverByName() is not virtual.
Now then could I create new files if GDAL is loaded dynamically?
I am using latest GDAL source with VC++ 2010
I tried to search mail list but did not seem find anything.
Thank you very much,
Mikhail
