[gdal-dev] Re: Gdal2tiles in Gdal18 and creating KMZ files
Vadim Shlyakhov vadp.devl at gmail.com
Wed Feb 23 04:26:27 EST 2011
<gx:LatLonQuad> shouldn't make any difference as it's semantics nearly
the same as <LatLonBox>.
On Tue, Feb 22, 2011 at 11:38 PM, Roland Duhaime
<roland.duhaime at gmail.com> wrote:
> I have been working with the png creation option under "gdal_translate -of
> kmlsuperoverlay" to create kmz files that include transparency.  I haven't
> had much luck with controlling specific colors that becomes transparent, or
> even maintaining transparency in the source HFA file.  The handling of
> transparency is different from gdal2tiles, where I have had good results.
> This leads me back to gdal2tiles and attempting to create a kmz file from
> the tile structure.  The key difference I see between the .kml files using
> the two different processes is below.   In order to be able to compress the
> gdal2tiles output into one file, I believe that I may need to modify
> gdal2tiles.py to create the gx:LatLonQuad tag from section 1 below as
> opposed to the LatLonBox from section 2 below.  Does anyone know the
> difference between gx:LatLonQuad and LatLonBox before I decide if this
> change is appropriate?:
> (1) KML Superoverlay snippet:
>         <GroundOverlay>
>             <drawOrder>0</drawOrder>
>             <Icon>
>                 <href>0.png</href>
>             </Icon>
>             <gx:LatLonQuad>
>                 <coordinates>
>                     -74.885604, 40.373168, 0
>                     -74.269963, 40.373582, 0
>                     -74.267506, 41.083329, 0
>                     -74.889723, 41.082904, 0
>                 </coordinates>
>             </gx:LatLonQuad>
>         </GroundOverlay>
> (2)GDAL2Tiles Kml snippet:
>         <GroundOverlay>
>           <drawOrder>16</drawOrder>
>           <Icon>
>             <href>159.png</href>
>           </Icon>
>           <LatLonBox>
>             <north>40.97989806962016</north>
>             <south>39.90973623453719</south>
>             <east>-74.53125000000000</east>
>             <west>-75.93750000000000</west>
>           </LatLonBox>
>         </GroundOverlay>
> Thanks Again,
> Roland
> On Sun, Feb 20, 2011 at 6:12 AM, Vadim Shlyakhov <vadp.devl at gmail.com>
> wrote:
>> brian <rush <at> winkey.org> writes:
>> > the problem is in /12/1211/2558.kml line 26
>> > <href>2558.png</href>
>> > this should be a relative path from the root of the zipfile not from
>> > 2558.kml
>> Hello Brian,
>> I've made another tile cutter (http://code.google.com/p/tilers-tools/). It
>> produces a directory tree in a manner which is very similar to
>> gdal2tiles.py. So
>> I had a look into this problem.
>> I must say it didn't work for me either: GE shows KML just fine, but if I
>> zip a
>> dir tree into KMZ it fails altogether. I've tried relative paths to PNGs,
>> to
>> internal KMLs. All these were to no avail.
>> I think that the problem actually lies in '<NetworkLink>' things and I
>> still
>> cannot get a clue on these.
>> I wonder if you have (or can produce manually) a sample of working KMZ
>> with
>> superoverlays, so I'd be able to have a look
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
