[gdal-dev] How to use GDAL C++ dynamically?
Mikhail Tchernychev
mikhail_tche at sbcglobal.net
Wed Feb 23 23:33:36 EST 2011
Hello Frank,
Yes indeed there are many functions which are not declared as virtual.
Thank you very much for pointing in right direction.
Cheers,
Mikhail
> Folks, I will note that at one time I maintained a "bridge" mechanism
> which basically did this. It dynamically loaded the C API at runtime.
> I stopped maintaining it several years ago but you can still find it
> in old code branches. ie.
> http://svn.osgeo.org/gdal/tags/gdal_1_2_0/bridge/ If someone felt it
> was really useful, that might be a good place to start. Best regards,
