[gdal-dev] Re: [Qgis-developer] Issue saving shapefiles with
REAL15 values
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Feb 25 08:22:43 EST 2011
Anita,
OGR's shapefile driver is reading the large values correctly is able to
display them with ogrinfo.
However, newly created .dbf files get the value -2147483648.
You can track further development regarding this at
http://trac.osgeo.org/gdal/ticket/3982
On Fri, Feb 25, 2011 at 3:04 AM, Anita Graser <anitagraser at gmx.at> wrote:
> Hi,
> Thanks for your help. I've attached a sample with faulty values
> Best wishes,
> Anita
> Am 22.02.2011, 17:39 Uhr, schrieb Chaitanya kumar CH <chaitanya.ch@
> gmail.com>:
> Anita,
>> Is it possible to send a small sample data to my email for testing?
>> Doesn't
>> matter if the ID field values are wrong.
>> On Tue, Feb 22, 2011 at 9:21 PM, Anita Graser <anitagraser at gmx.at> wrote:
>> Hi,
>>> I used the following ogr2ogr command:
>>> ogr2ogr -sql "select * from nw where NAME = 'Am Johannesberg'" new.shp
>>> nw.shp
>>> The resulting shp contains correct geometries, but the values in
>>> ID,N,15,0
>>> fields are broken.
>>> I guess that shows that it's a GDAL/OGR problem.
>>> Thanks, best wishes,
>>> Anita
>>> Am 22.02.2011, 16:33 Uhr, schrieb Chaitanya kumar CH <chaitanya.ch@
>>> gmail.com>:
>>> Anita,
>>>> First, let us isolate the source of this error. QGIS or GDAL/OGR.
>>>> Use ogr2ogr to clip the part you did with QGIS. See the extents of the
>>>> clipped shapefile using ogrinfo and use it with the ogr2ogr utility.
>>>> http://www.gdal.org/ogr2ogr.html
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110225/e7814d40/attachment.html
