[gdal-dev] gdalinfo crash on a jpeg 2000 file
N. Farah nfarah at hotmail.com
Sun Feb 27 18:02:31 EST 2011
Using gdalinfo from GDAL 1.8 release build (http://vbkto.dyndns.org:1280/sdk/) on this jpeg 2000 file(http://www.openjpeg.org/samples/Facade.j2k) crash !
To debug it I built gdal from source and registered only open jpeg 2000 driver: it appears that a unhandled exception wasthrown at this line if(!opj_read_header(pCodec, &psImage, &nX0, &nY0, &nTileW, &nTileH, &nTilesX, &nTilesY, pStream))in JP2OpenJPEGDataset::Open method.
The used openjpeg.dll is the one that come with http://vbkto.dyndns.org:1280/sdk which i assume was a private build fromthe open jpeg branch or trunk.
Should i file this as ticket with GDAL or probably with open jpeg 2000 ?
Thanks
Noureddine Farah
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110227/3ace3eb6/attachment.html
