[gdal-dev] Unrecognized Geopdf files using GDAL 1.8
N. Farah
nfarah at hotmail.com
Sun Feb 27 20:34:14 EST 2011
Thanks !
Yes I meant http://www.agc.army.mil/GeoPDFgallery/3D/Fargo.pdf
It makes sense then for this file and http://www.agc.army.mil/GeoPDFgallery/3D/Fargo_May09_geo.jpgif they were 3D or/and not following the OGC spec.
I believe poppler packaged with http://vbkto.dyndns.org:1280/sdk might be 0.15.1 and apparently0.16.0 had changes that probably made http://acrobatusers.com/sites/default/files/gallery_pictures/GEOEYE-INAUGURATION.pdfrecognized as valid GeoPdf.
Noureddine Farah
> From: even.rouault at mines-paris.org
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Unrecognized Geopdf files using GDAL 1.8
> Date: Mon, 28 Feb 2011 00:42:34 +0100
> CC: nfarah at hotmail.com
> Le lundi 28 février 2011 00:26:43, N. Farah a écrit :
> > Hi,
> > Using gdalinfo (http://vbkto.dyndns.org:1280/sdk/) on few geopdf files did
> > not recognized the files as supported.Other files were opened and
> > recognized ok. Here are 3 files that were unrecognized:
> > http://www.agc.army.mil/GeoPDFgallery/3D/Fargo.jpg
> --> this is a JPEG file ...
> You probably meant http://www.agc.army.mil/GeoPDFgallery/3D/Fargo.pdf which is
> recognized as a *non* spatial PDF on Linux with Poppler 0.16.0. A dump of the
> PDF content shows that there are indeed no spatial info in that PDF that
> follow the OGC best practice encoding or Adobe supplement to ISO 32000. And
> the name of the file suggests that this is a 3D GeoPDF, which is a specification
> not handled by the driver.
> Same as above
> INAUGURATION.pdf
> --> recognized as a geospatial PDF on Linux with Poppler 0.16.0
> Driver: PDF/Geospatial PDF
> Files: GEOEYE-INAUGURATION.pdf
> Size is 1350, 619
> Coordinate System is:
> PROJCS["WGS 84 / UTM zone 18N",
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4326"]],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-75],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> AUTHORITY["EPSG","32618"],
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH]]
> GeoTransform =
> 322005.63038904, 2.8993752, -0.04217184
> 4307533.17691748, -0.13576416, -2.77423392
> Metadata:
> NEATLINE=POLYGON ((322005.69019039417617
> 4307537.110892030410469,325915.627076361211948
> 4307346.153255709446967,325893.724369931151159
> 4305634.64386628754437,321983.72777434962336
> 4305821.667495521716774,322005.630388610996306
> 4307533.176889259368181,322005.69019039417617 4307537.110892030410469))
> Corner Coordinates:
> Upper Left ( 322005.630, 4307533.177) ( 77d 3' 9.14"W, 38d53'55.17"N)
> Lower Left ( 321979.526, 4305815.926) ( 77d 3' 8.62"W, 38d52'59.48"N)
> Upper Right ( 325919.787, 4307349.895) ( 77d 0'26.58"W, 38d53'52.05"N)
> Lower Right ( 325893.683, 4305632.645) ( 77d 0'26.09"W, 38d52'56.36"N)
> Center ( 323949.656, 4306582.911) ( 77d 1'47.61"W, 38d53'25.77"N)
> > Thanks
> > Noureddine Farah
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110227/92dc3617/attachment.html
