[gdal-dev] Re: PCIDSK .pix feature attribute information not visible in geomatica.
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Jan 3 23:25:16 EST 2011
Shashi,
Did you try the ogr2ogr utility?
On Mon, Jan 3, 2011 at 8:22 PM, shashishaw <shashishaw at gmail.com> wrote:
> Hi,
> I'm still not able to get past this problem. Can someone suggest any
> pointers as to which aspect of the conversion should I look into.. Any help
> is appreciated.
> Thanks,
> Shashi
> http://osgeo-org.1803224.n2.nabble.com/PCIDSK-pix-feature-attribute-information-not-visible-in-geomatica-tp5871388p5880861.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110104/eff347cd/attachment.html
