Fwd: Re: [gdal-dev] FWTools and GDAL 1.7.0
Tamas Szekeres
szekerest at gmail.com
Thu Jan 6 06:38:36 EST 2011
2011/1/6 Ari Jolma <ari.jolma at gmail.com>
> GDAL is available but again typically as MS compiler builds - which should
> not be a problem in theory because the bindings use it through the C API.
> I've tried to use those a couple of times without luck (compiling the
> bindings in MinGW was the problem). Maybe I should try again using binaries
> from Tamas' site.
> I agree that there could be a one main site for GDAL Windows binaries
> (something like http://www.gtk.org/download-windows.html). Tamas' site
> looks good but I'd like to have dev packages also (the SDK packages there
> look old) - just the header files should be enough.
Ari,
The SDK packages from http://vbkto.dyndns.org/sdk/ are exactly the same
which have been used to compile the daily builds, so it should be up to
date. The only thing may have to be done is to download the required version
of the gdal sources in the root folder, because not all of the versions
included in the package in order to keep the size as small as possible.
BTW: What is the desired practice to install the gdal files + bindings along
with a pre-installed perl runtime on Windows? Something like we have been
discussing for python in this thread, do we have some desired install
locations, environment settings or packaging conventions?
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110106/74448967/attachment.html
