[gdal-dev] SAGA: problem to convert grid from ETRS 89 / ETRS-LAEA
to WGS84 CRS
Volker Wichmann
Volker.Wichmann at uibk.ac.at
Thu Jan 6 07:27:01 EST 2011
This seems to me like an integer overflow - looking at the GDAL 1.7.2
sources I see, that the WriteHeader() method of sagadataset.cpp is using
GInt16 nXSize, GInt16 nYSize
Most likely this should be changed to
int nXSize, int nYSize
Best regards,
Volker
Am 06.01.2011 10:48, schrieb Clément Tisseuil:
> Dear all,
> I try to convert a SAGA grid (SAGA), from a ETRS 89 / ETRS-LAEA to
> WGS84 CRS , but I get the following error message:
> gdalwarp -s_srs "+proj=laea +lat_0=52 +lon_0=10 +x_0=4321000
> +y_0=3210000 +ellps=GRS80 +units=m +no_defs" -t_srs "+proj=longlat
> +ellps=WGS84 +datum=WGS84 +no_defs" -r near -of SAGA hdr.sdat ./tmp/hdr.sdat
> Creating output file that is 39901P x 15248L.
> ERROR 1: Invalid dataset dimensions : -25635 x 15248
> Any ideas ?
> Thanks in advance.
> Clément
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
