[gdal-dev] to create "transparent" image
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Jan 7 08:26:58 EST 2011
Ahmet,
Use the gdal_rasterize utility with a combination of the command line
options -a_nodata and -init with the same value.
To achieve transparency with the alpha band, give a fourth value for the
-burn option and make sure to include the fourth band with the -b option.
2011/1/7 ahmet temiz <ahmettemiz88 at gmail.com>
> hello
> Could you possibly give me an idea to create a "transparent" image
> from a shape file ?
> how can I do that ?
> regards
> Ahmet Temiz
> Jeoloji Müh.
> Planlama ve Zarar Azaltma Dairesi Başkanlığı
> Bilgi ve CBS grubu
> Eskişehir Yolu 10. km.
> Lodumlu / Ankara
> Tel : 0 312 2872680 / 1535
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110107/448aee8f/attachment.html
