Fwd: Re: [gdal-dev] FWTools and GDAL 1.7.0
Joaquim Luis jluis at ualg.pt
Fri Jan 7 10:26:33 EST 2011
On 07-01-2011 15:07, Jason Roberts wrote:
> Tamas,
> WIX looks like a great technology for building the installation
> package. I've never used it but I took a quick look and it seems to
> provide what is needed.
> As I understand it, you are pondering whether it would be better to
> have GDAL in Program Files\OSGeo\GDAL or in Program Files\GDAL. Is it
> simply a question aesthetics or principle, in which it seems proper to
> put all OSgeo projects under Program Files\OSGeo, but there could be
> problems coordinating the efforts of multiple projects to adhere to
> that carefully and not mash each other's files? If that summarizes the
> issue, then I'd recommend going with the more practical, less
> principled approach: put GDAL in Program Files\GDAL, and OSGeo4W in
> Program Files\OSGeo4W. It could get messy if both installers have to
> be able to create the Program Files\OSGeo directory but not
> necessarily delete it when they are uninstalled, because there could
> be another OSGeo project in there.
Let me just recall that OSGeo4W proposes the default install directory
as C:\OSGeo4W
This is just my opinion and I feel quite at rest because I'm able to
build GDAL and install it wherever I wont, but I would really hate that
an installer would force me to install in a location contrary to my
will. In particular when that location has blanks in the name (Program
Files).
But, as I said it's just my private view.
Joaquim
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110107/397a694b/attachment.html
