[gdal-dev] FWTools and GDAL 1.7.0
Jonathan.Shaw at gdc4s.com
Fri Jan 7 11:35:28 EST 2011
So far, it sounds like I will have to build GDAL, with various options, third party plugins, and libraries configured for the build, in order to get the capabilities that I currently use from FWTools. (Unless a new release of FWTools is made, but that seems unlikely to occur at this point.)
The idea of a GDAL installer for Windows is definitely appealing. As an end product integrator, I won't be able to use the proposed Windows installer unless I continue to have a way to use GDAL's C, C++, and .NET APIs, and to add-in drivers that weren't included in the Windows installer.
Anyway, I'm just wish listing. :)
Jonathan
-----Original Message-----
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jürgen E. Fischer
Sent: Friday, January 07, 2011 5:40 AM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] FWTools and GDAL 1.7.0
Hi Jonathan,
On Thu, 06. Jan 2011 at 22:06:06 -0700, Jonathan.Shaw at gdc4s.com wrote:
> To bring this up to the capabilities that I already use from FWTools, how
> would an end user like myself add in support for additional formats (e.g.
> JPEG2000, MrSID) and .NET bindings?
If the ECW and MrSID DLLs are added into the addons directory creatensis.pl
would include them in the installer along with the gdal17-ecw and gdal17-mrsid
packages from OSGeo4W. The standalone QGIS installer already does that.
No idea about the .NET bindings. Those should probably be put into OSGeo4W
first.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
