[gdal-dev] Hierarchical Data Format-EOS 2 conversion in Gdal
    Adam Bausch
    abausch at nova.whrc.org
    Tue Jan 11 09:20:47 EST 2011
Hi Nikolaos,
I wish I were using the level 2 product in .N1 format but the level 3
MERIS mosaics are processed to .hdf - EOS2.  I can work with N1 data
just fine if that were the case, but batch processing with BEAM doesn't
support what I am trying to do with HDF's (unless I could program in
Java..yikes)
Best,
Adam
On 1/10/11 10:54 PM, Nikolaos Hatzopoulos wrote:
> from here:
> http://www.brockmann-consult.de/cms/web/beam/meris-products
> I download this file which is level2 data:
> http://www.brockmann-consult.de/beam/data/products/MER_FR__2PNEPA20030714_102918_000000982018_00094_07162_0053.zip
> gdalinfo gives me:
> Driver: ESAT/Envisat Image Format
> Files: MER_FR__2PNEPA20030714_102918_000000982018_00094_07162_0053.N1
> Size is 2241, 2241
> Coordinate System is `'
> GCP Projection =
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         TOWGS84[0,0,0,0,0,0,0],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0,
>         AUTHORITY["EPSG","8901"]],
>     UNIT["degree",0.0174532925199433,
>         AUTHORITY["EPSG","9108"]],
>     AUTHORITY["EPSG","4326"]]
> GCP[  0]: Id=1, Info=
>           (0.5,0.5) -> (10.599538,56.49672,0)
> Metadata:
> MPH_PRODUCT=MER_FR__2PNEPA20030714_102918_000000982018_00094_07162_0053.N1
>   MPH_PROC_STAGE=N
>   MPH_REF_DOC=PO-RS-MDA-GS2009_11_3J
>   MPH_ACQUISITION_STATION=PDHS-K
>   MPH_PROC_CENTER=E-PAC
>   MPH_PROC_TIME=04-AUG-2003 15:12:31.508420
>   MPH_SOFTWARE_VER=MERIS/4.06
>   MPH_SENSING_START=14-JUL-2003 10:26:32.276537
>   MPH_SENSING_STOP=14-JUL-2003 10:32:37.452300
>   MPH_PHASE=2
>   MPH_CYCLE=+018
>   MPH_REL_ORBIT=+00094
>   MPH_ABS_ORBIT=+07162
>   MPH_STATE_VECTOR_TIME=14-JUL-2003 10:27:00.000000
>   MPH_DELTA_UT1=-.359896
>   MPH_X_POSITION=+2948879.180
>   MPH_Y_POSITION=+0636697.527
>   MPH_Z_POSITION=+6488093.331
>   MPH_X_VELOCITY=+6793.676563
>   MPH_Y_VELOCITY=-1452.749368
>   MPH_Z_VELOCITY=-2938.824735
>   MPH_VECTOR_SOURCE=FR
>   MPH_UTC_SBT_TIME=14-JUL-2003 10:18:36.710154
>   MPH_SAT_BINARY_TIME=+2483253760
>   MPH_CLOCK_STEP=+3906249805
>   MPH_LEAP_UTC=17-OCT-2001 00:00:00.000000
>   MPH_LEAP_SIGN=+001
>   MPH_LEAP_ERR=0
>   MPH_PRODUCT_ERR=1
>   SPH_SPH_DESCRIPTOR=MER_FR__2P SPECIFIC HEADER
>   SPH_STRIPLINE_CONTINUITY_INDICATOR=+000
>   SPH_SLICE_POSITION=+001
>   SPH_NUM_SLICES=+001
>   SPH_FIRST_LINE_TIME=14-JUL-2003 10:29:18.385327
>   SPH_LAST_LINE_TIME=14-JUL-2003 10:30:56.938607
>   SPH_FIRST_FIRST_LAT=+0056496720
>   SPH_FIRST_FIRST_LONG=+0010599537
>   SPH_FIRST_MID_LAT=+0057382170
>   SPH_FIRST_MID_LONG=+0006097018
>   SPH_FIRST_LAST_LAT=+0058099238
>   SPH_FIRST_LAST_LONG=+0001394104
>   SPH_LAST_FIRST_LAT=+0050903410
>   SPH_LAST_FIRST_LONG=+0007084803
>   SPH_LAST_MID_LAT=+0051698757
>   SPH_LAST_MID_LONG=+0003106173
>   SPH_LAST_LAST_LAT=+0052354870
>   SPH_LAST_LAST_LONG=-0001001598
>   SPH_TRANS_ERR_FLAG=0
>   SPH_FORMAT_ERR_FLAG=0
>   SPH_DATABASE_FLAG=0
>   SPH_COARSE_ERR_FLAG=1
>   SPH_ECMWF_TYPE=1
>   SPH_NUM_TRANS_ERR=+0000000000
>   SPH_NUM_FORMAT_ERR=+0000000000
>   SPH_TRANS_ERR_THRESH=+0.00000000E+00
>   SPH_FORMAT_ERR_THRESH=+0.00000000E+00
>   SPH_NUM_BANDS=+015
> SPH_BAND_WAVELEN=+0000412545+0000442401+0000489744+0000509700+0000559634+00006
> 19620+0000664640+0000680902+0000708426+0000753472+0000761606+0000778498+00008648
> 33+0000884849+0000899860
> SPH_BANDWIDTH=+09930+09946+09965+09971+09983+09991+09994+07493+09996+07493+037
> 42+15000+19999+09990+09989
>   SPH_INST_FOV=+0000019159
>   SPH_PROC_MODE=1
>   SPH_OFFSET_COMP=1
>   SPH_LINE_TIME_INTERVAL=+0000043997
>   SPH_LINE_LENGTH=+02241
>   SPH_LINES_PER_TIE_PT=+064
>   SPH_SAMPLES_PER_TIE_PT=+064
>   SPH_COLUMN_SPACING=+2.60000000E+02
> DS_LEVEL_1B_PRODUCT_NAME=MER_FR__1PNEPA20030714_102918_000000982018_00094_0716
> 2_0120.N1
> DS_AEROSOL_CLIMATOLOGY_FILE_NAME=MER_AER_AXVIEC20030620_120000_20020321_193100
> _20200101_000000
> DS_PROCESSING_PARAMS_L2_FILE_NAME=MER_CP2_AXVIEC20030620_120000_20021224_12144
> 5_20121224_121445
> DS_ATMOSPHERIC_PARAMETERS_FILE_NAME=MER_ATP_AXVIEC20030620_120000_20021224_121
> 445_20121224_121445
> DS_WATER_VAPOUR_PARAMETERS_FILE_NAME=MER_WVP_AXVIEC20030620_120000_20020321_19
> 3100_20120321_193100
> DS_OCEAN_AEROSOLS_PARAMS_FILE_NAME=MER_OAP_AXVIEC20030620_120001_20020321_1931
> 00_20120321_193100
> DS_LAND_AEROSOLS_PARAMS_FILE_NAME=MER_LAP_AXVIEC20030715_151450_20020321_19310
> 0_20120321_193100
> DS_OCEAN_I_PARAMETERS_FILE_NAME=MER_OC1_AXVIEC20030620_120000_20020321_193100_
> 20120321_193100
> DS_OCEAN_II_PARAMETERS_FILE_NAME=MER_OC2_AXVIEC20030620_120000_20020321_193100
> _20120624_174339
> DS_CLOUD_MEASUREMENT_FILE_NAME=MER_CMP_AXVIEC20030620_120000_20021224_121445_2
> 0120321_193100
> DS_LAND_VEGETATION_INDEX_FILE_NAME=MER_LVI_AXVIEC20030620_120000_20020321_1931
> 00_20130224_164916
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0, 2241.0)
> Upper Right ( 2241.0,    0.0)
> Lower Right ( 2241.0, 2241.0)
> Center      ( 1120.5, 1120.5)
> Band 1 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(1)
> Band 2 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(2)
> Band 3 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(3)
> Band 4 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(4)
> Band 5 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(5)
> Band 6 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(6)
> Band 7 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(7)
> Band 8 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(8)
> Band 9 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(9)
> Band 10 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(10)
> Band 11 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(11)
> Band 12 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(12)
> Band 13 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Norm. rho_surf - MDS(13)
> Band 14 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = YS, SPM, Rect. Rho- MDS(16)
> Band 15 Block=2241x1 Type=UInt16, ColorInterp=Undefined
>   Description = Epsilon, OPT   - MDS(19)
> I am using centos linux
> On Mon, Jan 10, 2011 at 12:54 PM, Adam Bausch <abausch at nova.whrc.org
> <mailto:abausch at nova.whrc.org>> wrote:
>     Hi,
>     I get the following error.
>     GDALOpen failed - 4
>     `H29V13.hdf' not recognised as a supported file format.
>     Thanks for the link.
>     Adam
>     On 1/10/11 3:31 PM, Nikolaos Hatzopoulos wrote:
>>     what gdalinfo gives you?
>>     this is a very helpful link http://www.gdal.org/frmt_hdf4.html
>>     On Mon, Jan 10, 2011 at 10:19 AM, Adam Bausch
>>     <abausch at nova.whrc.org <mailto:abausch at nova.whrc.org>> wrote:
>>         Hi All,
>>         I am attempting to process a large volume of MERIS mosaic
>>         data obtained from ENVISAT in HDF-EOS2 format, however, I
>>         continue to get a "not a supported format" error when I try
>>         to run it.  I have installed the HDF-4 (libdf), HDF-5
>>         (libhdf5) and NetCDF libraries and checked with our
>>         Linux/Unix administrator to try and identify the problem with
>>         no resolution.  I was wondering if anyone else has had this
>>         problem or if there is a fix.
>>         Best,
>>         Adam
>>         _______________________________________________
>>         gdal-dev mailing list
>>         gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110111/742b3e18/attachment-0001.html
