[gdal-dev] gdalwarp with gauss resampling
Jan Hartmann j.l.h.hartmann at uva.nl
Wed Jan 12 08:53:11 EST 2011
Is it possible to use gauss resampling with gdalwarp? The current
resampling options (cubic, bilinear etc) work very well as long as the
pixels in input and output rasters are about the same size, but not very
well when downsampling to a much coarser scale. Gdaladdo has gauss
resampling, but only for overviews of an existing file. I want to
combine many mapsheets into one large map at a much lower resolution
using gauss resampling. Would it make sense/be possible to add gauss
resampling to gdalwarp itself/ Alternatively, is it possible to extract
the overviews from a gdaladdo-ed file als regular rasters?
Jan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110112/a0f0d946/attachment.html
