[gdal-dev] OGR : Shapefile driver limits column name to 10 chars
Even Rouault even.rouault at mines-paris.org
Wed Jan 12 11:28:56 EST 2011
Selon Anders Moe <anders.moe at geocap.no>:
Try looking for "dbf field names limited to 10 characters" in your favorite
search engine and you should get the answer ;-)
The OGR shapefile driver mentions just before "Shapefile feature attributes are
stored in an associated .dbf file, and so attributes suffer a number of
limitations". That also gives you an hint on where the limitation comes from...
> Hi all
> The OGR shapefile driver has a documentet caveat in that column names can
> not exceed 10 characters:
> http://www.gdal.org/ogr/drv_shapefile.html
> <http://www.gdal.org/ogr/drv_shapefile.html>Does anyone know if this is an
> inherent limitation of the shapefile format or within the OGR driver ? Any
> possibility that this will be lifted ? I'm using GDAL 1.7,
> Regards,
> Anders
