[gdal-dev] gdalwarp to VRT. How to set "-multi" option? How to get best performances when chaining gdal operations?
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Thu Jan 13 05:07:24 EST 2011
Hi list,
I have a thousand of file with SRS A which I will to mosaic, reproject to
SRS B and then retile (I will use GDAL 1.7.2).
What I will do is:
1- setting up a VRT using gdalbuildvrt on top of the original TIF files.
2- reprojecting it to an intermediary VRT using gdalwarp (to SRS B).
3- retiling the reprojected VRT as 32768x32768 (or something smallers)
geotiffs with gdal_retile by also adding JPEG compression, inner 512x512
tiling and bicubic interpolation on intermediate levels
How can I get best performances with this operations chaining?
>From [1], I see I can play with "--config GDAL_CACHEMAX xxxx -wm xxxx" when
invoking gdalwarp. (I will set GDAL_CACHEMAX as an environment var)
I see that the wm parameter as well as inner tiling are set on the
reprojected.vrt as GDALWarpOptions.
Is there a way to set the "-multi" parameter in the reprojected vrt too to
make use of this feature to separate thread for I/O and thread for
computation?
Regards,
Daniele
[1]: http://trac.osgeo.org/gdal/wiki/UserDocs/GdalWarp
Ing. Daniele Romagnoli
Software Engineer
GeoSolutions S.A.S.
Via Poggio alle Viti 1187
55054  Massarosa (LU)
Italy
phone: +39 0584962313
fax:     +39 0584962313
mob:   +39 328 0559267
http://www.geo-solutions.it
http://geo-solutions.blogspot.com/
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110113/75e4d6c8/attachment.html
