[gdal-dev] [ogr] Unexplained third dimension in linear ring
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Jan 14 11:07:56 EST 2011
Alex,
I thought of pretty much the same modification. But it could potentially
break some software. It may be added in 1.8 which is in the process of being
released but I doubt it. Please file the ticket.
On Fri, Jan 14, 2011 at 9:27 PM, Alex Hagen-Zanker <ahh34 at cam.ac.uk> wrote:
>  The problem seems to be that adding a 2D OGRPoint  to a 2D OGRLinearRing
>> results in a 3D OGRLinearRing.
> Sorry to bother you with this, I found it myself.
> It is the following function in ogrlinestring.cpp that looks like a bug to
> me:
> void OGRLineString::setPoint( int iPoint, double xIn, double yIn, double
> zIn )
>    if( getCoordinateDimension() == 2 )
>        Make3D();
>    if( iPoint >= nPointCount )
>        setNumPoints( iPoint+1 );
>    paoPoints[iPoint].x = xIn;
>    paoPoints[iPoint].y = yIn;
>    if( zIn != 0.0 )
>        Make3D();
>        padfZ[iPoint] = zIn;
>    else if( getCoordinateDimension() == 3 )
>        padfZ[iPoint] = 0.0;
> How about changing it to this:
> zIn )
>    if( zIn != 0.0 &&  getCoordinateDimension() < 3 )
>        Make3D();
>        padfZ[iPoint] = zln;
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110114/0c9fd9d6/attachment-0001.html
