[gdal-dev] Importing and exporting shapefiles in mySQL with OGR
Chaitanya kumar CH
chaitanya.ch at gmail.com
Mon Jan 17 08:30:04 EST 2011
Markus,
Run the ogrinfo utility on the MySQL database created from the shapefile and
the original MySQL database and compare them. You should be able to build a
command according to the differences.
On Mon, Jan 17, 2011 at 12:55 PM, "Dr. Markus Müller" <
markus.u.mueller at zoho.com> wrote:
> Dear listers,
> I am trying to get shapefiles in and out of a mySQL database using OGR. I
> found some example commands for importing and succeeded in doing this. But
> getting the syntax together to get a spatial dataset out of mySQL db seems
> to be over my head.
> Can anybody supply an example command to convert from mySQL to shape? Or is
> it just not possible to export geodata from mySQL into shapefiles using OGR?
> Thanx and best regards
> Markus
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110117/685279ab/attachment.html
