[gdal-dev] Problem with ogrinfo and KML files
Chaitanya kumar CH chaitanya.ch at gmail.com
Tue Jan 18 08:36:20 EST 2011
Massimo,
Do you see KML in the list of formats shown when you run the command
"ogrinfo --formats"?
What was the error message you got? Can you provide a sample file?
On Tue, Jan 18, 2011 at 6:54 PM, massimo costantini <
massimo.costantini at gmail.com> wrote:
> Hi,
> I've try to analize KML files with ogrinfo but it seems to not
> recognize the format. Gdal is compiled with expat support.
> Someone can tell me the reason and the solution for this problem?
> thanks
> Massimo Costantini
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110118/5a9e74c4/attachment.html
