[gdal-dev] Generating GDAL Native Dependencies
Sam Ritchie sritchie09 at gmail.com
Tue Jan 18 14:53:38 EST 2011
One final question, moved to its own thread.
Is there a simple way to generate GDAL's native java dependencies
(libgdalconstjni.*, libgdaljni.*, libogrjni.*, libosrjni.*, where * depends
on the architecture) without having to build the rest of the gdal source
code? I'm going to dig around the source code myself, of course, but it
would be quite handy if one could build these native dependencies for other
architectures.
Are they available, for the compiled binary of gdal? Or is the only solution
really to build the source code with all relevant options, and then make
inside swig, then make in java?
Thanks so much, all,
Sam
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110118/02997052/attachment.html
