[gdal-dev] question about reading grib2 file
Matt Funk
mafunk at nmsu.edu
Thu Jan 20 17:52:50 EST 2011
Hi Bill,
thank you. That information helps a lot.
Sorry, as i said, i am pretty new with this stuff.
But it makes sense now.
thanks
matt
On 1/20/2011 3:24 PM, Cassanova, Bill wrote:
> Hi Matt,
> Can you be a little more explicit about what you are asking? Generally speaking GRIB2 files do not contain explicit lat-lon information.
> GRIB2's contain a projection and within that projection the bounding box including the number of points along each axis is contained.
> As an experiment run gdalinfo on your grib2 file and you will see output similar to the below:
> gdalinfo foo.grib2
> Driver: GRIB/GRIdded Binary (.grb)
> Files: foo.grib2
> Size is 720, 361
> Coordinate System is:
> GEOGCS["Coordinate System imported from GRIB file",
> DATUM["unknown",
> SPHEROID["Sphere",6371229,0]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]]
> Origin = (0.000000000000000,270.000000000000000)
> Pixel Size = (0.500000000000000,-0.500000000000000)
> Corner Coordinates:
> Upper Left ( 0.000, 270.000) ( 0d 0'0.01"E,270d 0'0.00"N)
> Lower Left ( 0.0000000, 89.5000000) ( 0d 0'0.01"E, 89d30'0.00"N)
> Upper Right ( 360.000, 270.000) (360d 0'0.00"E,270d 0'0.00"N)
> Lower Right ( 360.000, 89.500) (360d 0'0.00"E, 89d30'0.00"N)
> Center ( 180.000, 179.750) (180d 0'0.00"E,179d45'0.00"N)
> Band 1 Block=720x1 Type=Float64, ColorInterp=Undefined
> Description = 0[-] SFC="Ground or water surface"
> Metadata:
> GRIB_UNIT=[K]
> GRIB_COMMENT=Temperature [K]
> GRIB_ELEMENT=TMP
> GRIB_SHORT_NAME=0-SFC
> GRIB_REF_TIME= 1295481600 sec UTC
> GRIB_VALID_TIME= 1296151200 sec UTC
> GRIB_FORECAST_SECONDS=669600 sec
> GRIB_PDS_PDTN=0
> GRIB_PDS_TEMPLATE_NUMBERS=0 0 2 0 96 0 0 0 1 0 0 0 186 1 0 0 0 0 0 255 0 0 0 0 0
> If you are trying to read the values contained in Upper Left, Lower Left, etc?
> If this is the case you need to get the geo_transform using code similar to the C-code below:
> GDALAllRegister();
> GDALDatasetH my_data_set;
> int my_x_size, my_y_size;
> int my_raster_bands;
> GDALRasterBandH my_raster_band;
> double my_geo_transform[6];
> std::string my_projection_ref;
> my_data_set = NULL;
> my_raster_band = NULL;
> my_x_size = my_y_size = my_raster_bands = 0;
> ACE_LOG_MSG->log(LM_INFO, "%D %n Opening %s \n", input_grib2_file.c_str());
> my_data_set = GDALOpen(input_grib2_file.c_str(), GA_ReadOnly);
> if (NULL == my_data_set)
> ACE_LOG_MSG->log(LM_INFO, "%D %n NULL GDALDatasetH pointer for file %s, "
> "file invalid, quitting\n", input_grib2_file.c_str());
> return (1);
> GDALGetGeoTransform(my_data_set, my_geo_transform);
> my_x_size = GDALGetRasterXSize(my_data_set);
> my_y_size = GDALGetRasterYSize(my_data_set);
> my_raster_bands = GDALGetRasterCount(my_data_set);
> "%D %n Data Set: x_size = %d y_size = %d raster_bands = %d origin = %f, %f, pixel_size=%f, %f\n",
> my_x_size, my_y_size, my_raster_bands, my_geo_transform[0],
> my_geo_transform[3], my_geo_transform[1],
> my_geo_transform[5]);
> >From this information you can calculate the lat-lon of each point within the file.
> To answer your other question about wgrib2 -spread....wgrib2 calculates the lat-lon coordinates on the fly and does not store these explicitly in the file...Unless they are put there as a wgrib2 data segment which most people don't do.
> Hope this helps,
> Bill
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Matt Funk
> Sent: Thursday, January 20, 2011 4:38 PM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] question about reading grib2 file
> Hi,
> i am somewhat new to gdal and the grib format.
> I need to read in a grib2 file which contains latitude longitude and
> elevation.
> So i do:
> ds = gdal.Open(filename)
> and
> print "ds.GetRasterCount(): %s" % ds.GetRasterCount()
> gives: 1
> I can proceed to read in this band, but all the data that i get is the
> elevation.
> Not sure if this is an incredibly stupid question, but how do i access
> the latitude/longitude data?
> I know that there is latitude/longitude since when outputting things to
> a csv file via the wgrib2 utility i get lat/lon and elevation?
> thanks for any advice
> matt
> gdal-dev mailing list
