[gdal-dev] Problem with GDAL Python bindings and ECW format under
Windows
Tamas Szekeres
szekerest at gmail.com
Tue Jan 25 15:03:14 EST 2011
2011/1/25 Jason Roberts <jason.roberts at duke.edu>
> Tamas,
> Could you improve the Windows GDAL installer, so that it automatically sets
> the environment variables (GDAL_DATA and GDAL_DRIVER_PATH), and adds the
> GDAL binaries path to the PATH environment variable ?
I will do some improvements in the installers to make the things easier.
Modifying the environment should only be happen upon the user's request and
shouldn't be done automatically in my opinion. I would create a custom
dialog in the installer where the user can allow this setting to be happen.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110125/2b771180/attachment.html
