[gdal-dev] Re: Problem with GEOTIFF
Fernando Cacciola fernando.cacciola at gmail.com
Wed Jan 26 22:53:03 EST 2011
Hi Frank,
>> so it seems like the data is there after all.
> Ah. I suspect this is a problem with having both an .aux and .aux.xml file.
> I suppose the .aux file is being used and the .aux.xml file is ignored.
> Try moving the .aux file somewhere out of the way and see if things
> behave more properly.
That was a very good guess, but unfortunately it didn't change anything :(
> If you can make the dataset available I might be able to improve the
> robustness of the logic for the case with a .aux and .aux.xml file.
It'd be great if you can take a look at it.
Though even zipped is too big for an attachment. Do I email it to you?
Best regards
Fernando Cacciola
SciSoft Consulting, Founder
http://www.scisoft-consulting.com
