[gdal-dev] Problem with GDAL Python bindings and ECW format under
Windows
Chris Barker
Chris.Barker at noaa.gov
Wed Jan 26 23:31:37 EST 2011
On 1/25/11 4:07 PM, Jason Roberts wrote:
> I didn't think we were discussing platform-independent solution for
> linking bindings with the GDAL libs, as different operating systems
> have radically different installation locations.
sure, but pure python that points to a path, it a lot easier than
looking in the registry for something.
> The existing
> platform-independent way to do it is to put GDAL's binary directory
> in the PATH. That is what I thought we were trying to get away from
> on Windows, in an attempt to solve DLL hell and the "just works"
> requirement at the same time.
I thought having python set the PATH at the beginning o of the import
was idea -- that way it wouldn't mess up anything else.
> Anyway, this is why we need an RFC, as Frank requested.
yup
> I still
> intend to write one when I can get free from my day job
> responsibilities, assuming someone else doesn't write one first...
I'm waiting for you... ;-)
Thanks,
-Chris
> Jason
> -----Original Message----- From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Christopher
> Barker Sent: Tuesday, January 25, 2011 6:50 PM To:
> gdal-dev at lists.osgeo.org Subject: Re: [gdal-dev] Problem with GDAL
> Python bindings and ECW format under Windows
> On 1/25/11 2:57 PM, Jason Roberts wrote:
>> Rather than introduce a DLL into the system directory, why not
>> statically link the code into the bindings themselves, when
>> possible?
> we did go through that, and it's one option, but for those of us
> that use gdal with C programs, python, with the utilities, all --
> it's nice to know that you're using the exact same version for
> everything.
>> document the appropriate logic for doing it with win32 functions
>> (registry functions, LoadLibrary, GetProcAddress) and allow the
>> bindings to make those calls themselves? Most languages have a way
>> to access win32 functions.
> yeah, but ugly and platform dependent. (of course, I just have a
> distaste for the registry)
> I thought we had more or less come up with a consensus that the
> language bindings (Python, anyway) would take care of finding gdal
> and setting up the environment, and that we would facility things
> "just working" by using standard install locations.
> This would let casual users have a simple "run the installers and it
> works" experience, but more sophisticated users could easily
> customize their systems, have multiple versions installed, etc.
> And no installers would set anything up system wide.
> (though I have no problem with a "check this if you want the
> Environment set up" box in the gdal installer)
>> It just seems unnecessarily risky and complicated to create a new
>> DLL and put it in the system directory, IMHO.
> agreed.
> -Chris
