[gdal-dev] Can I use ogr2ogr to postgresql with security?
Mike Axelrod
mike.axelrod at pictometry.com
Thu Jan 27 15:21:13 EST 2011
Thank you, I’ll be trying that out as soon as I get our postgresql server configured with ssl. Do you know if the postgresql public key is required on the client side? I see references to a ~/.postgresql/postgresql.key being available to the client. But I’m not clear if this is required or an option.
BTW I’m currently using the win32 SDK version of ogr2ogr that is distributed here => http://vbkto.dyndns.org/sdk/, I’m hoping these builds support SSL. Can anybody confirm?
Mike
From: Chaitanya kumar CH [mailto:chaitanya.ch at gmail.com]
Sent: Thursday, January 27, 2011 2:56 PM
To: Mike Axelrod
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Can I use ogr2ogr to postgresql with security?
Mike,
OGR's postgresql/postgis driver makes the connection using PQconnectdb() method from the libpq library.
You can set the option 'sslmode' to 'require', 'verify-ca' or 'verify-full' for a secure connection. Look for the documentation of PQconnectdb() for further details.
On Fri, Jan 28, 2011 at 12:13 AM, Mike Axelrod <mike.axelrod at pictometry.com<mailto:mike.axelrod at pictometry.com>> wrote:
Does ogr2ogr (and ogrinfo) natively support secure connections to postgresql?
I need to run ogrinfo and ogr2ogr where the target is a postgresql server elsewhere on the network (in a different domain) and secure the communication.
Mike
Mike Axelrod, Software Engineer
Pictometry International Corp.
Suite A, 100 Town Centre Drive, Rochester, NY 14623
Phone: 585-775-7711
E-mail: mike.axelrod at pictometry.com<mailto:mike.axelrod at pictometry.com> Web: http://www.Pictometry.com/<http://www.pictometry.com/>
NOTICE: This message is covered by the Electronic Communications Privacy Act, Title 18, United States Code, Sections 2510-2521. This e-mail and any attached files are the exclusive property of Pictometry International Corp., are deemed privileged and confidential, and are intended solely for the use of the individual(s) or entity to whom this e-mail is addressed. If you are not one of the named recipient(s) or believe that you have received this message in error, please delete this e-mail and any attachments and notify the sender immediately. Any other use, re-creation, dissemination, forwarding or copying of this e-mail is strictly prohibited and may be unlawful.
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110127/9b418c4b/attachment-0001.html
