[gdal-dev] Can I use ogr2ogr to postgresql with security?
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jan 27 16:11:37 EST 2011
Mike,
To use SSL mode with OGR, your pqlib should be built with SSL support.
On Fri, Jan 28, 2011 at 2:09 AM, Mike Axelrod
<mike.axelrod at pictometry.com>wrote:
>  So it seems the build I’m using may not support ssl, I run ogrinfo with
> sslmode=prefer I connect ok, but when I set sslmode=require I get this
> error:
> Details...
> call to ogrinfo failed: ERROR 1: PQconnectdb failed.
> sslmode value "require" invalid when SSL support is not compiled in
> *From:* gdal-dev-bounces at lists.osgeo.org [mailto:
> gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Mike Axelrod
> *Sent:* Thursday, January 27, 2011 3:21 PM
> *To:* Chaitanya kumar CH
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* RE: [gdal-dev] Can I use ogr2ogr to postgresql with security?
> Thank you, I’ll be trying that out as soon as I get our postgresql server
> configured with ssl.  Do you know if the postgresql public key is required
> on the client side?  I see references to a ~/.postgresql/postgresql.keybeing available to the client. But I’m not clear if this is required or an
> option.
> BTW I’m currently using the win32 SDK version of ogr2ogr that is
> distributed here => http://vbkto.dyndns.org/sdk/, I’m hoping these builds
> support SSL.  Can anybody confirm?
> Mike
> *From:* Chaitanya kumar CH [mailto:chaitanya.ch at gmail.com]
> *Sent:* Thursday, January 27, 2011 2:56 PM
> *To:* Mike Axelrod
> *Subject:* Re: [gdal-dev] Can I use ogr2ogr to postgresql with security?
> Mike,
> OGR's postgresql/postgis driver makes the connection using PQconnectdb()
> method from the libpq library.
> You can set the option 'sslmode' to 'require', 'verify-ca' or 'verify-full'
> for a secure connection. Look for the documentation of PQconnectdb() for
> further details.
> On Fri, Jan 28, 2011 at 12:13 AM, Mike Axelrod <
> mike.axelrod at pictometry.com> wrote:
> Does ogr2ogr (and ogrinfo) natively support secure connections to
> postgresql?
> I need to run ogrinfo and ogr2ogr where the target is a postgresql server
> elsewhere on the network (in a different domain) and secure the
> communication.
> Mike
> Mike Axelrod, Software Engineer
> Pictometry International Corp.
> Suite A, 100 Town Centre Drive, Rochester, NY 14623
> Phone: 585-775-7711
> E-mail: mike.axelrod at pictometry.com Web: http://www.Pictometry.com/<http://www.pictometry.com/>
> NOTICE: This message is covered by the Electronic Communications Privacy
> Act, Title 18, United States Code, Sections 2510-2521. This e-mail and any
> attached files are the exclusive property of Pictometry International Corp.,
> are deemed privileged and confidential, and are intended solely for the use
> of the individual(s) or entity to whom this e-mail is addressed. If you are
> not one of the named recipient(s) or believe that you have received this
> message in error, please delete this e-mail and any attachments and notify
> the sender immediately. Any other use, re-creation, dissemination,
> forwarding or copying of this e-mail is strictly prohibited and may be
> unlawful.
> gdal-dev mailing list
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
> unlawful.
> unlawful.
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110128/be834276/attachment-0001.html
