[gdal-dev] JPEG compressed GeoTIFF ignores Nodata
Even Rouault
even.rouault at mines-paris.org
Sat Jan 29 10:13:02 EST 2011
Le samedi 29 janvier 2011 15:47:43, Marius Jigmond a écrit :
> Hi Everyone,
> I am having some trouble figuring out why adding JPEG compression to a
> RGB GeoTIFF results in Nodata pixel triplets becoming data pixel
> triplets. Is this expected behavior due to the noisy nature of JPEG
> compression or to the fact that these are border Nodata triplets? I know
> certain algorithms process the boundary between data and Nodata
> differently.
Marius,
Yes you did find the cause : the pixels maching nodata values will be JPEG
compressed, so you have no guarantee that the 0 value is preserved through
compression/decompression. I'd also note that the nodata concept in GDAL is a
per-band value (so it should not be interpreted as a nodata "triplet")
A possibility to workaround this would be to create a "nodata mask band" (see
http://trac.osgeo.org/gdal/wiki/rfc15_nodatabitmask), but I'm pretty sure that
QGIS ignores those mask bands.
Anyway, if you want to try and create one, you can :
1) Use nearblack to create a nodata mask band based on (0,0,0) triplet
nearblack -setmask -of GTiff -o out_with_mask.tif in.tif
(the -setmask option is new in GDAL 1.8.0)
2) Then compress the dataset with
gdal_translate -co COMPRESS=JPEG -co TILED=YES -co JPEG_QUALITY=90 -co
PHOTOMETRIC=YCBCR out_with_mask.tif out_compressed.tif
Only the RGB channels will be JPEG compressed : the mask band will use
lossless compression so you won't have artifacts at the borders between
significant areas and nodata areas.
(You can add --config GDAL_TIFF_INTERNAL_MASK YES to make the nodata mask
internal to the GTiff file, instead of having a .tif.msk external file, which
will not make any difference for software using GDAL API but can be more
convenient to have a sinle file)
FYI, you can later reconvert the dataset into an uncompressed RGBA dataset :
gdal_translate out_compressed.tif out_rgba.tif -b 1 -b 2 -b 3 -b mask
Best regards,
Even
