[gdal-dev] reproject
Sat Jan 29 11:56:36 EST 2011
On 11-01-29 04:55 AM, Mohammed Rashad wrote:
> is there any function in ogr to export the projection string to proj4.
> there is a function called importFromProj4 but nothing like export from proj4.
> i have the wkt of projection read from .prj file
> I need to convert it to proj4 string.
Rashad,
The method is OGRSpatialReference::exportToProj4().  There are corresponding
C, C#, python, java, etc entry points.
Best regards,
