[gdal-dev] GDAL 1.8 - Switch Thrown
Tamas Szekeres szekerest at gmail.com
Sun Jan 30 15:39:58 EST 2011
Ari,
Assuming you did mention to compile the Perl bindings with MinGW could you
describe the steps of the compilation in more detail? (by using the files
downloaded from http://vbkto.dyndns.org/sdk.) Which packages should be
installed as the prerequisites of the compilation?
I admit I'm not an expert in MinGW but it would be quite helpful on my side
to be able to reproduce the issue you are talking about. I would also be
curious to know how the perl tests are executed in this case.
Best regards,
Tamas
2011/1/30 Ari Jolma <ari.jolma at gmail.com>
>  29.1.2011 20:43, Tamas Szekeres kirjoitti:
> Ari,
> I would be eager to know the exact use case you have. Did you have some
> errors provided by the linker in this case?
> For the stdcall functions I added entries like this
> _CPLDefaultErrorHandler at 12
> CPLDefaultErrorHandler = _CPLDefaultErrorHandler at 12
> to the .def file. I create the .dll.a, which is the import library, with
> dlltool from the .def.
> There are no errors from the linker. If I leave the stdcall entries as they
> are from pexports, i.e., just
> The linker complains about undefined reference to `CPLDefaultErrorHandler'
> However, running the Perl tests fail with "The procedure entry point
> CPLDefaultErrorHandler could not be located in the dynamic link library
> gdal17.dll". This is no wonder since the Perl bindings GDAL.dll imports
> CPLDefaultErrorHandler from gdal17.dll. I believe this because I'm misusing
> the .def file or dlltool does not understand that CPLDefaultErrorHandler is
> an alias to _CPLDefaultErrorHandler at 12.
> I saw a web page which seemed to say that this is a known problem in
> dlltool and it had a small hack for dlltool.c to fix the problem, but I
> don't find the page just now and I've not yet tried hacking the dlltool.c
> (it seems quite possible).
> I think the cdecl functions work ok.
> If I compile GDAL in MSYS, all functions are exported cdecl.
> Ari
> It would indeed be a problem how the various compilers decorate their
> export functions in a different way. It looks like the __declspec(dllexport)
> option (this is what is used in GDAL) provides different names with MSVC and
> MinGW by default. If we want to compile the dlls in a portable way we should
> probably get back to an alternative method like .def file or "#pragma
> comment( linker, "/export:FuncName" )" when exporting the functions.
> The article you are referring to describes another way of providing a
> portable version that is:
> 1. Compile the dll as it is now (the functions exported
> with__declspec(dllexport))
> 2. Extract the export functions in a .def file by using pexports
> 3. Replace the function names with their undecorated names in the .def file
> 4. Recompile the dll with this new export definition file.
> I'm keen to give it a try if I get some further info about how to test this
> on the other side.
> Best regards,
> Tamas
> 2011/1/29 Ari Jolma <ari.jolma at gmail.com>
>> Did anybody else try to use the now standard Visual Studio built GDAL DLL
>> (which was much discussed some time ago here and is now available from
>> Tamas' site) in a MinGW environment?
>> I spent some time a week or two ago on the issue, but I had a hard time,
>> which AFAIK is because the DLL mixes two function export methods and thus
>> using the standard tools seems difficult if not impossible (I already
>> downloaded the sources for latest GNU dlltool and considered hacking it...)
>> The best page about the issue I found so far is this:
>> http://wyw.dcweb.cn/stdcall.htm
>> Anybody have any ideas? Is my observation about the two export methods
>> correct and why is that?
>> Ari
>> On 01/29/2011 04:59 AM, Frank Warmerdam wrote:
>>> Folks,
>>> I have had good success with the GDAL 1.8 upgrade and I have now thrown
>>> the switch migrating it into the production version of OSGeo4W.
>>> I have upgraded "gdal", "gdal-python", "gdal-mrsid" and "gdal-autotest".
>>> I have yet to upgrade the ecw, and sde related drivers, and I have not
>>> upgraded the java bindings.  I will try to work on them tomorrow.
>>> The gdal15dll package was created for backward compatability and should
>>> be automatically pulled in.  It seems to be working fine for OpenEV.
>>> I would encourage folks building packages to update, and rebuild them
>>> using the current GDAL.  The GDAL include files in C:\OSGeo4W\include
>>> and libraries in C:\OSGeo4w\lib should now be for 1.8.
>>> Note that the new GDAL package is built using Visual Studio 2008
>>> Express instead of 2003.  If you are using the C++ API this may cause
>>> issues but if you use the C API it should be invisible.
>>> Let me know of problems.
>>> Best regards,
>>   _______________________________________________
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110130/ae9c3188/attachment.html
