[postgis-devel] [gdal-dev] Bogus <gml:Face> interpretation
strk strk at keybit.net
Mon Jan 31 08:45:07 EST 2011
On Mon, Jan 31, 2011 at 06:33:46PM +0530, Chaitanya kumar CH wrote:
> strk,
> You are right. The sequence of the elements _can_ be specified explicitly
> using a sequence tag. Without that it will just be a guess work, especially
> if any of the rings have a common point.
Ah, great to hear that.
This means postgis would not even need to construct the face geometries
in order to output the GML, as all the required information is already
in the normalized alphanumeric relations instead.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
