[gdal-dev] C# bindings - ReadRaster & WriteRaster overloads in Band
class
James Domingo
jdomingo at green-code.com
Fri Jul 1 22:45:10 EDT 2011
A question about the GDAL C# bindings. The overloads for the ReadRaster and
WriteRaster methods in the Band class take several different type of buffers:
ReadRaster(..., byte[] buffer, ...)
ReadRaster(..., short[] buffer, ...)
ReadRaster(..., int[] buffer, ...)
ReadRaster(..., float[] buffer, ...)
ReadRaster(..., double[] buffer, ...)
I was wondering why there are no overloads for the unsigned integer types
that GDAL supports, e.g., unsigned 16-bit and 32-bit integers:
ReadRaster(..., ushort[] buffer, ...)
ReadRaster(..., uint[] buffer, ...)
The C# SWIG interface file (trunk/gdal/swig/include/csharp/gdal_csharp.i)
has lines that appear to define these overloads:
/*! Sixteen bit unsigned integer */ //%rasterio_functions(DataType.GDT_UInt16,ushort)
/*! Thirty two bit unsigned integer */ //%rasterio_functions(DataType.GDT_UInt32,uint)
but there is no information as to why they are commented out. Was it to
maintain CLS-compliance?
Thanks,
Jimm
James Domingo
Green Code LLC
