[gdal-dev] Strange error on gdalAllRegister()
Fri Jul 1 23:12:08 EDT 2011
On 11-07-01 04:29 PM, Rodolfo Bonnin wrote:
> Hello All,
> I'm writing two new drivers ( For ALOS PRISM and AVNIR-2 ) and I'm trying to
> add them to the list of drivers.
> I've added them to gdal_frmts.h:
> void CPL_DLL GDALRegister_PRISM(void)
> void CPL_DLL GDALRegister_AVNIR2(void)
> gdalallregister.cpp: In function 'void GDALAllRegister()':
> gdalallregister.cpp:483: error: 'GDALRegister_AVNIR2' was not declared in this
> scope
> gdalallregister.cpp:484: error: 'GDALRegister_PRISM' was not declared in this scope
Rodolfo,
I hope you actually terminated the prototypes in gdal_frmts.h with a
semi-colon!  Things should be working if the right copy of gdal_frmts.h
is being pulled into gdalallregister.cpp.  I'm not sure why you are
having problems.
Best regards,
