[gdal-dev] Add capability to safely link against an external
libtiff (3.X) and a GDAL build with internal libtiff (4.0) support
Even Rouault
even.rouault at mines-paris.org
Sun Jul 3 13:02:03 EDT 2011
> Do you have some particular indication about how to test it?
> Which test programs did you use?
My tests mainly consisted in checking that GDAL would compile and link
successfully with various combinations of the configure options.
With the renaming options enabled, I did a "objdump -t libgdal.so | awk
'{print $6}' | grep TIFF | grep -v TIFFjpeg_ | grep -v aig_ | grep -v gdal_ |
sort -u" to ensure that all the symbols that should be renamed are. You will
notice a few remaining occurrences but I think they are safe.
Also, when the renaming options where enabled, I added -ltiff -lgeotiff to the
gdalinfo linking line, before or after -lgdal, and tested the executable on a
few files.
> It seems to me that people of the the OTB project had serious problems
> with this issue in the past and they have a fantastic test framework.
> Maybe we could also ask to them for a little help for testing.
Yes indeed, I had CC'ed Julien Malik who is affiliated with the OTB project in
my announcement email.
> ciao
