[gdal-dev] OGR : OCI driver improvement
Nicolas Simon nicolas.simon at spw.wallonie.be
Mon Jul 4 11:22:46 EDT 2011
	I just answer most questions in my previous mail to the list.
	So just to say that I could participate to the maintenance of the OCI driver for OGR (we don't use raster in Oracle, sorry).
	Nicolas
> -----Message d'origine-----
> De : fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com]De la part de
> Frank Warmerdam
> Envoyé : lundi 4 juillet 2011 15:10
> À : Nicolas Simon
> Cc : gdal-dev at lists.osgeo.org
> Objet : Re: [gdal-dev] OGR : OCI driver improvement
> Nicolas,
> The proposed changes seem reasonable, but I am concerned
> about complexity and
> risk of breaking the driver in some rarely tested cases.  The OCI
> driver is pretty
> fragile.
> On Mon, Jul 4, 2011 at 8:32 AM, Nicolas Simon
> <nicolas.simon at spw.wallonie.be> wrote:
> > Hi all,
> > I'd like to propose some OCI driver improvement.
> > 1) Enable insert from different client. This could be done
> by managing the generation of new FID on DB side instead of
> client side.
> > Technically this could be done with an oracle sequence and
> a trigger to fill the FID.
> > This proposition modify the way FID are handled ( I propose
> to do as in PostGIS driver). This means that the FID of a
> feature (i.e. usually the value of the OGC_FID column for the
> feature) inserted into a table with CreateFeature() will be
> retrieved from the database and can be obtained with GetFID()
> even if an non-null FID was provided.
> > This could be easily implemented in UnboundCreateFeature
> with a 'returning' clause.
> > But I don't known if it's feasible in BoundCreateFeature
> since truth FIDs will be know later when
> OGROCITableLayer::FlushPendingFeatures() is called.
> I'm not clear on what you will do if CreateFeature() is called on a
> table for which the
> the sequence and trigger to fill the FID do not already exist.  Will
> you create it?  I'm
> concerned this will not be honoured by other applications
> interacting with the
> table.
> > 2) By providing true update operation instead of delete +
> insert operations (cf SetFeture).
> > This should provide better performance and enable to
> develop trigger on update if needed for other purpose.
> > With this modification, OCI driver will have the following
> mapping between OGR concepts and Oracle operations:
> >    OGRFeature::CreateFeature() <==> INSERT operation
> >    OGRFeature::SetFeature() <==> UPDATE operation
> >    OGRFeature::DeleteFeature() <==> DELETE operation
> > This modify slightly the actual behavior since it disable
> the possibility of inserting a new record through SetFeature
> (in case of  they were no record to delete, the subsequent
> insert did the job). With the proposed implementation it'll
> be no longer the case.  "Update ... set ...  where FID =
> provided FID" command doesn't insert new record.
> The main downside I see with implementing SetFeature() as an UPDATE is
> complexity -
> another whole set of code for assigning records.  But that isn't a
> compelling reason
> not to do it.
> > 3) Add transaction support in the normal SQL sense.
> > Since transaction is handled within a session and we have a
> session per OGROCIDataSource, a transaction will include
> operation on any layer of that datasource.
> > I propose the following operating mode.
> > Outside a transaction, we'll be in 'auto commit' mode.
> >  This commit on success DeleteFeature, SetFeature and
> CreateFeature (not in MULTI_LOAD mode).
> >  For CreateFeature (in MULTI_LOAD mode) data will be commited
> >  - each time the buffer is full (when
> OGROCITableLayer::FlushPendingFeatures() is called)
> >  - when OGROCITableLayer::SyncToDisk() is call
> >  - before a new transaction start.
> > Transaction start (through a call
> OGRLayer::StartTransaction()) for all layer in the DataSource.
> > OGRLayer::CommitTransaction() will call
> OGROCITableLayer::SyncToDisk() for each layer of  the
> DataSource and issues one commit command for the session, and
> then return in auto commit mode (cf outside transaction mechanism)
> > OGRLayer::RollbackTransaction() will drop PendingFeature
> (may be  through a private function that reset
> nWriteCacheUsed to 0) for each layer of the datasource and
> issues one rollback command for the session, and then return
> to auto commit mode.
> This *seems* reasonable, but please understand that the OGR
> transaction
> model is fairly weak.
> > I would like to know if someone else is interested in these
> improvements ?
> > Is it the way you want things work ?
> > An other information is that I'm ready to work for these
> improvements.
> I think the changes are desirable (in trunk only!) but if you
> provide them
> I am hopefully you will take an ongoing interest in maintenance of the
> OCI driver.   Hopefully you might also be open to taking on commit
> access so you can do stuff more easily (perhaps after first submitting
> patches via trac for review).
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
